How to find attribute by other attribute
i want to know hou to use hdk get point attribute by another attribute, such as point id attribute,
because i want to match attribute between different sop,the point number is not the same,so i can not
use point offset to get attribute,
i want it like blendsop use id attribute to point position attribute at different frame
not sure about HDK, but if you are looking just for that functionality then
Find Attribute Value VOP or findattribval() VEX function is what you need
it will return pt number of the point(or other element) from given geometry with given int/string attribute value or -1 if not found
you can then use that pt number to import any attribute from that matching point
http://www.sidefx.com/docs/houdini13.0/vex/functions/findattribval
it's available since 12.5.192
Guest mantragora
Do you have any starting code?
I'm asking because you are the second person here, with a total post count = 1, that signs to odforce and the first thing you are doing is asking about HDK stuff that from my experience is not something that people new to this forum should start from. There is a chance that you have ton of Houdini experience we don't know of but I would prefer at least some sign from your side that you really know what you are talking/asking about.
Cheers
