for loop in one line
pelos
i am trying to put a code into a button that will print the values of some parameters, i was able to make a list with
t = [x for x in hou.pwd().parms() if x.name().startswith("blend")];
then i can print the list of the parameters that  i want with
print t;
but if i want to do something to each one is when starts to break:
t = [x for x in hou.pwd().parms() if x.name().startswith("blend")]; print t; for i in t:   print i.eval();
the funny thing is if i print all directly with out doing the filter list does work =(
for i in hou.pwd().parms():   print i.eval();
any cool tip that might work?
thanks.
You should be able to do something like this:
for i in (x for x in hou.pwd().parms() if x.name().startswith("blend")): print i.eval()
It removes one of the loops, but you also have to do it as a generator expression, rather than a list comprehension, thus the () instead of the [].
Unfortunately I'm not too sure about the intricacies about Python and single line statements.  It's also no a Houdini specific thing.  If you take the giant line from up there that doesn't work in Houdini, it doesn't work in Python either.
