indirectly refer to a parameter in expression?
locvio
a scripting question:
On SOP level,
object-merging an obj level object(say a camera)..
then in another node want to refer to the camera's aperture..
What is the way to do that? (Indirectly refer to a parameter in hscript)
something like this: (but this doesnt work :)
`ch("../object_merge3/objpath1")/aperture`
thanks!
Alex
(below  works with detail params in attribcreate, but is there a more streamlined way?)
attribcreate1:
aperturePath = `chs("../object_merge3/objpath1")`/aperture
attribcreate2:
aperture = $APERTUREPATH
Edited by locvio
so if chsop("../object_merge3/objpath1") will give you path to your camera
then
ch(chsop("../object_merge3/objpath1") + "/aperture")
will give you aperture value
or even this will work:
ch(chs("../object_merge3/objpath1") + "/aperture")
