Is there a way to constrain particles to a surface while they are movi
magneto
Lastly when should I be using Timeinc in my code? I didn't realized I had to here.
it all comes to understanding of the data you need to manipulate and how the solver is using it
so for example v stores distance per second
but the introduced P displacement by snapping it to the surface was done in each timestep and v from that would be distance per timestep
so to convert it to distance per second you need to divide it by timestep which is represented by @Timeinc and contains currently simulated fraction of the time
the whole timestep handling is necessary because it's variable and depends on your FPS and number of substeps, but you expect similar results per second so this conversion is crucial
So if I had to update force, I would use Timeinc there too?
in this case yes, it would be the same, the force from the displacement would be just per timestep you need to convert it to per second as solver will multiply force by @Timeinc (and divide by @mass if desired) before adding to v to properly add acceleration each timestep
but in case you are setting force that is already in seconds then no
If that's the case, should you also be using it in VEXpressions to change parameter values?
usually no, parameters represent values per second so you want to work with them like that
or even if the values are not per second, they are usually being adjusted internally to account for timestep
you should treat VEXpressions on parameters as literally just setting values of that parameter per particle
