-HEAVY- Posted February 7, 2014 Share Posted February 7, 2014 Hey =)at the moment i am modifing a GlueNetwork at SOP Level and deleting more and more parts of the network via Group and a scaling Bounding Box. That works good so far and give me a lot of controll over the destruction but cause the glue_fractured_import SOP is locally so it doesnt go with the RBD motion in the DOP network.So what is the way to go for a setup where for example the glued object is falling through an imaginary plane or an static object that deletes the network ? cheerzde -HEAVY- Quote Link to comment Share on other sites More sharing options...
rayman Posted February 10, 2014 Share Posted February 10, 2014 Connect Sop Solver to glue network inside dops. This will give you dynamic constraint network. If you use shelf tools to create gluenet Sop solver is created by default. Quote Link to comment Share on other sites More sharing options...
-HEAVY- Posted February 10, 2014 Author Share Posted February 10, 2014 (edited) do you have a explanatory file so we talk about the same when we mean "dynamic" - cause i create glue Network with shelf - and i have now dynamic update while the pieces are falling:ok i have a scenen here to demonstrate.Basic glue network - fractures are falling - but what i want is that while the pieces are falling through secondary_area (at Fr.30) the glue network updates and deletes the connections hitting that area...?!hopefully that makes sense...thx de Heavy Heavy_GLUE_Test.hipnc Edited February 10, 2014 by -HEAVY- Quote Link to comment Share on other sites More sharing options...
-HEAVY- Posted February 11, 2014 Author Share Posted February 11, 2014 ok i put together a smaller example...as you can see the bricks are falling but the glue does not update. The technic is based on the Bullet Masterclass by Jeff Wagner- but he used some older build with different Glue Network so his example files update fine with falling pieces. but when i Import my geo in his setup the glue network changes from frame 1 to 2 significantly and is not scalable to bigger Networks. and please dont tell me to change override with sops - if it would be that sinple i have had found it today so please please somebody tell me what´s wrong ! thx de Heavy Quote Link to comment Share on other sites More sharing options...
Lucas van Rossum Posted November 2, 2014 Share Posted November 2, 2014 Hi Heavy Have you found a solution to your problem. thx Quote Link to comment Share on other sites More sharing options...
