magneto Posted February 8, 2014 Share Posted February 8, 2014 Hi, It seems like I asked this before but for changing it in code, which doesn't exist or the surface which involves using 2 Convert SOPs. I have the same idea for changing the NURBS curve order but I find it hard to believe this is the only way. Is there a way to do this using another SOP? I tried the Basis SOP and changed the order there but it didn't do anything when I checked the order in the Details View. Thanks Quote Link to comment Share on other sites More sharing options...
Annon Posted February 8, 2014 Share Posted February 8, 2014 SortSOP Quote Link to comment Share on other sites More sharing options...
magneto Posted February 8, 2014 Author Share Posted February 8, 2014 Thanks Christian but are you sure you can do it with a Sort SOP? Because I am trying to change the NURBS spline order (2-11), not the primitive number. Quote Link to comment Share on other sites More sharing options...
petz Posted February 9, 2014 Share Posted February 9, 2014 Hi, It seems like I asked this before but for changing it in code, which doesn't exist or the surface which involves using 2 Convert SOPs. I have the same idea for changing the NURBS curve order but I find it hard to believe this is the only way. Is there a way to do this using another SOP? I tried the Basis SOP and changed the order there but it didn't do anything when I checked the order in the Details View. Thanks the basis sop should do that. could you upload the file where it does´t? petz 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks petz, I attached it. I thought that was normal because the parameter says "Raise U To", so assumed it only goes up, not down. nurbsorder.hip Quote Link to comment Share on other sites More sharing options...
