[solved] How do I make the object_merge node use the parent object nod
DASD
For purposes of organisation, rigging and usability I want to import geometry from the connected input of an object node (that is form the parent object level node).
For this purpose I use an object_merge node and I want to script the path in "Object n".
In the python shell
hou.node('..').inputs()[0].path() + "/"
gives me the path I need. But it does not work when I put it in the "Object n" slot and set the node scripting language to python. I tried to put the code in backticks, but that hasn't worked either.
I am thankful for all advice.^^
Edited by DASD
- First click on the parameter and make sure it's background is reversed. This puts it into expression mode
- Now when you right-click on it, you can choose: Expressions > Edit expression
- Type in your expression and hit apply
- You should get an error, because it's not set in python yet.
- To change it to python, right click on the name and choose Expressions > Change language to Python
- Hit apply again to see that you get no more errors, then hit Accept
