copying normals
3__
Hey cpb,
You *can* use a point sop as well...
1. Append a point sop
2. Feed the destination sop (the one that is to receive the normals) into input #1 of the pointSOP
3. Feed the source sop (the one you're copying from) into input #2 of the pointSOP
4. In the Standard tab of the pointSOP, where it says "Keep Normal", change it to "Add Normal".
5. Change the three normal fields (which default to $NX, $NY, and $NZ) to $NX2, $NY2, $NZ2 respectively. You're effectively assigning to input#1, the normals from input#2.
Make sense?
Cheers!
  • 2 weeks later...
