Break wire off geometry if at certain angle
Mala
I'm trying to create an expression in Houdini's Hscript to break the wires off the surface off an object when they reach a certain angle.
so far I have this
for i=0 to $P step 2
    set even = "$i"
    set odd = "$even+1"
    while ($F == 0)
    set vec_normal = "odd.$P - even.$P " # find vector at frame 0
        # echo vec_normal
    end
    while ($F > 0)
    set vec_moving = "odd.$P - even.$P" # find vector at other frames
        # echo vec_moving
    end
    if (vangle(vec_normal,vec_moving) > 40)
        echo null
    else
        echo even
    endif
end
but it doesn't work...
I was wondering if anyone could help me with this?
Thanks in advance!
  • 1 month later...
