mbdunaway Posted February 20, 2014 Share Posted February 20, 2014 (edited) Hey folks, I've got a little problem with my UVs. I have created a model in Houdini that has procedural animation setup in the extrudes. I am then exporting the model and setting up the UVs in another package and bringing that model back in and then copying the UVs to the original. Reason for this is that I want to keep control of the animation.The problem is that while the UVs copy correctly, AttribCopy isn't recognizing the cut seams which is giving me overlapping UVs.Any way to fix this? Edited February 20, 2014 by mbdunaway Quote Link to comment Share on other sites More sharing options...
SpencerL Posted February 20, 2014 Share Posted February 20, 2014 make sure your uvs are a vertex attribute and not a point attribute Quote Link to comment Share on other sites More sharing options...
abvfx Posted February 21, 2014 Share Posted February 21, 2014 I had this problem a few times with Zbrush and its pointgroups (Zbrush messes with models they have them). If your model is identical to the one you exported and did the UVs, apply a "matchtopology" sop. Then do an attributecopy and it should work fine. Quote Link to comment Share on other sites More sharing options...
mbdunaway Posted February 21, 2014 Author Share Posted February 21, 2014 Yeah, it was coming out scrambled when I did vertex attribute instead of point, but the match topography sop fixed it.Thanks all! Quote Link to comment Share on other sites More sharing options...
