opdigit equivalent
just repost the goal of that on sidefx forum
hi,
Is there a way to pass an attribut when packing an object, as the "name" can be retrieved to intrinsic_fragmentname.
One solution that I found is to concat my custom attribut in the name then retrieve it with the opdigit expression. (see the hip)
But the opdigit expression is really slow to evaluate and with a lot pack primitive is not a viable solution.
thank,
papi
Your file has incomplete asset definition but you don't need a new SOP to do this. Just use something like this in AttribWrangle
string s = primintrinsic(ch("parm"),"fragmentname",@primnum);
s@__foo=s;
string items[] = split(s, "_");
s@first= items[0];
