Is it possible to detect similarity in different music tracks using Ho
magneto
Since Houdini has extensive audio capabilities, can this be done? Someone here must have tried to do this :)
Similarity can be in many aspects so I am not exactly sure which ones I should be looking for but I mean to be able to find similarly sounding tracks this way:
http://www.soundsjustlike.com/2721/the-verve-sounds-like-the-andrew-oldham-orchestra/
I don't know if it's best to just compare 2 tracks and see how close they are to each other, or come up with a way that maps the music into a much smaller data set like a 3d volume and then use that to calculate a single value to then sort a whole library of music using this value in the order of similarity?
This is just something I had in mind for a while but I don't know how to do it.
