VEX supports array function?
ciel9979
Hi, this is my first post here. :)
I've been trying to call a vector array function in VEX, but it either returned "Internal Compiler Error" or "Syntax error, unexpected identifier, expecting ';'". I also checked Array help file and the example as below didn't work at all:
To specify a literal array, use curly braces, with the array members separated by commas:
vector[] rgb_array()
return { {1, , }, {, 1, }, {, , 1} };
Here is the simple code I tried to compile, but it returned an error message "Syntax error, unexpected identifier, expecting ';'." :(
vector an_array[] = {{1,1,1}, {2,2,2}};
vector a[];
vector[] testFunction(vector[] a){
    return a;
a=testFunction[an_array];
Does anyone know if VEX supports array function? Thank you very much!
Thanks for your reply, magneto. My codes are in snippet vop inside the attribVOP. For those non-array functions like "vector testFunction(vector a)", they work, but not for "vector[] testFunction(vector[] a)" -_-
Maybe it's VEX that hasn't supported array functions yet :(
  • 2 years later...
Wrangles (more generally, functions defined inside other functions), still not support returning arrays in Houdini 15.5. Most convenient workaround is modifying an argument.
In code file:
float[] foo()
    return array(1, 2, 3, 4, 5);
bar = foo();
In wrangle:
void foo(float arr[])
    arr = array(1, 2, 3, 4, 5);
foo(bar);
  • Thanks 1
  • 2 years later...
