schiho Posted February 24, 2014 Share Posted February 24, 2014 (edited) Hi guys, i am creating a "Font Sop" then i am using the "Polyextrude Sop", but as you can see, the mesh isn't quite clean, as the sop produces big ngons. In Softimage, there is the "text to curve converter" which produces a better tesellated mesh. Is there a way to do that in houdini? Thanks Edited February 24, 2014 by schiho Quote Link to comment Share on other sites More sharing options...
mangi Posted February 24, 2014 Share Posted February 24, 2014 Yafes, are you just looking for more detail in the text node ? Then : boost the detail value up some. mangi Quote Link to comment Share on other sites More sharing options...
schiho Posted February 24, 2014 Author Share Posted February 24, 2014 Hi Mike, nope, you can see the big face on the number "2", there is no tesellation, this is problematical when i export geo to maya. Quote Link to comment Share on other sites More sharing options...
mangi Posted February 24, 2014 Share Posted February 24, 2014 Okay Yafes I was not 100 % sure what you are trying to achieve. Quote Link to comment Share on other sites More sharing options...
mangi Posted February 24, 2014 Share Posted February 24, 2014 (edited) Yafes from your snap shot, I fabricated this . Let me export a obj and see if it works for your export into MAYA Cheers Mangi text.rarFetching info... Edited February 24, 2014 by mangi Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted February 24, 2014 Share Posted February 24, 2014 I tried a remesh sop and had success using it on the 2D Text, this might be an option if you need only triangles. Quote Link to comment Share on other sites More sharing options...
schiho Posted March 2, 2014 Author Share Posted March 2, 2014 Sorry for my late reply, @kunz07 this worked well. @mike maybe you can give me a hip file? I can load it, the problem is, while importing alembics, "some" ngons are blasted away, which is an undefined behaviour. Quote Link to comment Share on other sites More sharing options...
mangi Posted March 2, 2014 Share Posted March 2, 2014 Sure Yafes here is the scene mangi Y.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
