Apply shader to all objects in an alimbic
J_spad
Hello,
I do not normally post requests like this due to wanting to learn things for myself however I am under the gun. Can someone tell me how to loop through an alembic and assign a shader to all geometry nodes brought in? I have an alembic with 200+ objects on different levels of depth within the alembic and need to apply the same shader to all of them. I have tried just selecting and applying but it only works if I do the assigning one object at a time.
Thanks!
James S
So I got some python going but when I loop through it is unable to skip nodes that do that have the material path attribute. How do I add a conditional to only run the material assignment if it is a geo node?
>>> def print_tree(node, indent=0):
...     for child in node.children():
...         childaccess = child
...         matAssign = childaccess.parm('shop_materalpath')
...         matAssign.set('/shop/BoatSteel')
Edited by J_spad
I was able to get this output from this script:
>>> def assignMat(node):
...             try:
...                     print "Parm on Node! %s" %(childaccess)
...             except:
...                     print "No parm on Node %s" %(childaccess)
>>> assignMat(hou.node('/obj/animation/animationExport/css_atlanta_v17_css_atlanta'))
No parm on Node css_atlanta_v19_for_animation_css_atlanta
No parm on Node boatBody
No parm on Node boatBody1
No parm on Node Greats
It seems to only be checking the top level on  nodes. Any ideas on how I can go deeper?
Was able to get it working! If anyone needs to mass assign a shader to all the children of a node.....
for child in node.allSubChildren():
matAssign = child.parm('shop_materialpath')
if matAssign:
print "Parm found on Node......"
matAssign.set('/shop/myshader')
print "Parm on Node! %s" %(child)
else:
print "Parm not assigned to Node %s" %(child)
assignMat(hou.node('/obj/mynode'))
