Simple angle to point orient
jonathantopf
Hi there, I'm a new huodini user learning on the job after years using maya and this is my first odforce post after much reading.
I'm writing a very simple point wrangle node and the last step of the program involves turning a 0-1 rotation value representig a 360 rotation value in the Y axis into a per point orient value that a copy sop can then use to istantiate geometry with the correct orientation.
My problem is in converting these values, my first attempt was this
f@pi = 3.14159;
@orient = set( 0, (2 * @pi) * @y_rot, 0  );
I do get an orient value in the correct axis but not what i was expecting and is clearly wrong.
Can anybody shed some light on how to construct a simple @orient value from a simple xyz rotation
Thanks!
I believe orient is a vector pointing to a direction, not an array of Euler rotational values...
I could be wrong though! :)
Try this code:
float y_rot = 0;
y_rot = radians(random(@ptnum)*360);
vector axis = set(0, 1, 0);
vector4 Q = quaternion(y_rot, axis);
p@rot = set(Q);
rotation_and_copy.hip
Edited by rafaelfs
