Dops Pops Equivalent to Rotation, Velocity, Attribute
LaidlawFX
Hello,
I'm looking for the equivalent to the pops nodes rotation, velocity, and attribute in dop pops, trying to simply convert a H12 to H13 setup. Not sure if this need be an RFE, or if there is an equivalent already there.
Thanks
-Ben
For velocity and attribute, you should be able to use a popwrangle node for that.  Could also use it to set rotation, too, if you want to manually.  I believe rotations are currently done with the torque pop dop.
