Billowy Smoke from points
You have to change the Fluid Source SOP to "stamp points". One typical problem with these kind of setups is the resize node at DOPs tends to get a bit sloppy. Be sure it tracks the correct object.
I´m not too sure you´re gonna like the results of what you´re trying though. It usually delivers a "rounded" shape of emission that´s not very attractive visually.
You might want to use the pieces themselves...maybe just the interiors that are moving...
