halion Posted July 1, 2004 Share Posted July 1, 2004 Is there away to use the force sop in the pop network? I tired using the force pop and putting the force sop into the force object but that does nothing. Quote Link to comment Share on other sites More sharing options...
Lukich Posted July 2, 2004 Share Posted July 2, 2004 force sop adds forces to a metaball it's connected to, which get evaluated by the particles from the particle sop. If you want to achieve the same effect (spiral morion, tonados and such) inside the pops, try the attractor pop into which you put the force sop. I works almost exactly the same. Quote Link to comment Share on other sites More sharing options...
halion Posted July 2, 2004 Author Share Posted July 2, 2004 Thanks for the idea. I tried it out awhile ago but it doesn't seem to apply the force over the whole source sop. I tried just sticking the particle sop in and it seems to work from what I tried. So tomorrow I'll try some more stuff and hopefully it'll work right. Quote Link to comment Share on other sites More sharing options...
