tag geo that exceeds vel mag threshold as always 'on' subseque
gnarlog
Hello there,
I would like to take an alembic imported point cache and turn on the vertices based on some velocity magnitude threshold using a delete sop, but have them not turn back off(get deleted) when the velocity magnitude goes back below that threshold. I know this kinda thing is doable, but I suck at houdini. If anyone is feeling charitable, I'd really appreciate it.
Thanks a lot,
Matt
There are many ways to do this but if you just want to use a delete sop, make sure that your imported alembic is converted to either polys or points (you can just drop a convert node down after the alembic node if your uncertain) and has a velocity attribute (if it doesnt then drop down a trail attribute and set it to compute velocity) then set the delete sop to expression and use something like
length($VX,$VY,$VZ) < 5
getting the length of the velocity vector will basically give you the speed then its just about what you want the cutoff to be.
-N
