MagQ Posted April 17, 2014 Share Posted April 17, 2014 hi,guys Recently i did a simple test about houdini ocean render techniques and got some issuses. The problem is i dont know how to avoid this kind of bright speckles in PBR renders,any suggestions? please check the pic Thanks in advance MagQ Quote Link to comment Share on other sites More sharing options...
pezetko Posted April 17, 2014 Share Posted April 17, 2014 These are probably sharp bright speculars. Try to lower the Color Limit value (on mantra/shading tab) and rise Reflect Angle a little bit above zero on the ocean shader. 1 Quote Link to comment Share on other sites More sharing options...
MagQ Posted April 18, 2014 Author Share Posted April 18, 2014 These are probably sharp bright speculars. Try to lower the Color Limit value (on mantra/shading tab) and rise Reflect Angle a little bit above zero on the ocean shader. Thanks for your suggestions! But it doesn’t work at all unless I disable the environment light or change environment map,and my env map is nothing special,what's wrong? P.s. My Houdini version is 13, I use PBR Quote Link to comment Share on other sites More sharing options...
sunchao360 Posted April 18, 2014 Share Posted April 18, 2014 建议你关闭灯光里的反射试试。 1 Quote Link to comment Share on other sites More sharing options...
MagQ Posted April 18, 2014 Author Share Posted April 18, 2014 建议你关闭灯光里的反射试试。 请问灯光里的反射从哪里关呢? Quote Link to comment Share on other sites More sharing options...
old school Posted April 18, 2014 Share Posted April 18, 2014 Your environment map IBL must have a pretty hot tiny sun. I would think that the sharp highlights are the light reflection on your surface. Nothing special but probably everything. You can blur the IBL or adjust the balance to make the sun not has hot or larger. Try a different IBL's to see how the water surface reacts. You can increase the reflection angle to blur out the reflections a bit to see if it softens the highlights. Quote Link to comment Share on other sites More sharing options...
sunchao360 Posted April 21, 2014 Share Posted April 21, 2014 这个是灯光属性里面,主页面上有个添加,你把灯光反射,添加进去,把前面的勾号去掉。 Quote Link to comment Share on other sites More sharing options...
MagQ Posted April 21, 2014 Author Share Posted April 21, 2014 这个是灯光属性里面,主页面上有个添加,你把灯光反射,添加进去,把前面的勾号去掉。 可以了,谢谢你 Quote Link to comment Share on other sites More sharing options...
MagQ Posted April 21, 2014 Author Share Posted April 21, 2014 Your environment map IBL must have a pretty hot tiny sun. I would think that the sharp highlights are the light reflection on your surface. Nothing special but probably everything. You can blur the IBL or adjust the balance to make the sun not has hot or larger. Try a different IBL's to see how the water surface reacts. You can increase the reflection angle to blur out the reflections a bit to see if it softens the highlights. Unfortunately,those bright speckles on my surface aren`t the light reflection even i change a different environmet map. Increasing the reflection angle do blur out my "reflections" but my final image changed a lot. I am lucky guy,thanks for all your help,problem solved.Just as sunchao360 said,all i only need to disable the light contribution in the light tab,it wont change anything but my speckles Quote Link to comment Share on other sites More sharing options...
