Font SOP reading attribute from other SOP
Hello
Super basic question, but I can't seem to figure it out...How do you get a Font SOP to display the attributes of a say, a Box SOP.?  So for example if the box had a $V variable generated by a Trace SOP, how could I have the font SOP display that value?
Thanks
best way is to do an attribcreate where you create the attribute in question beforehand and assign a local variable to it.
or to do it through a point expression
point("../somenode",0,"attribute",0)
point(node,pointnr,attribname,attribIndex)
you can make the point expression look atht the input of the node it is in.
Hmm, I tried the first method, where I use an attributecreate and create a $POS local variable that reads the $TX,$TY,$TZ of my object.
Then I modified Eetu's expression to
This torus is `("../attribcreate1", $POS)` units wide
But I'm clearly not using the right syntax in this case right?
Thanks!
