compare 2channels in chops
i am comparing the rest distance between 2 nulls in chops with the object node. and i want to compare it against the animated distance. so i thought to put down a vopchop and just do some "if then".
so connecting  the 2 distances into the vopchop, but now inside the vopchop how to do i grab each one of them? so i can compare them? and export some value that i can use?
thanks.
