Pyro sim errors "explodes"
MartinuZ
I'm getting some weird simulation errors, see attached screenshots.
I have 5 objects that are traveling down a path and emitting smoke in a pyro container, but at a certain frame the smoke just explodes and houdini will freeze if left simulating (if i'm fast i can escape the sim)
does this look familiar to someone?
I've tried increasing substeps on the autodop network but that doesn't help..
regards,
Martijn
post-9069-0-98129200-1398673230_thumb.pn
post-9069-0-94896800-1398673235_thumb.pn
It seems my problem is solved by increasing max substeps on the pyrosolver to 2 and the cfl condition to 3..
I also forgot to mention that the emitters travel through the smoke in a vortex like motion, so I'm guessing that when a voxel gets 'overloaded' by smoke it will destabilize the simulation.
Is this a correct assumption?
edit:well it seems I cheered to soon, still getting the same errors..
so I'd still like to know what causes this..
edit2:
my problem is the same as here:
http://forums.odforce.net/topic/18923-vortex-force-blowing-up-smoke-sim/
the vortex was causing it, increasing the radius did help
Edited by MartinuZ
