nailcuter Posted May 3, 2014 Share Posted May 3, 2014 Hello, I wonder if anyone knows how to export flip fluid to maya using alembic. I tried it export alembic, but in Maya it said "not a valid alembic file".. Anyone has experience this ? Thanks! fluid box .hipnc Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted May 3, 2014 Share Posted May 3, 2014 There are some other threads about this. Some things to check are: - Must have geometry on first frame of export - Export alembic as HDF5 format (Not Ogawa which is the default on houdini rop) - Try exporting without any excess attributes (only P) Quote Link to comment Share on other sites More sharing options...
nailcuter Posted May 3, 2014 Author Share Posted May 3, 2014 Got it thank you ! Quote Link to comment Share on other sites More sharing options...
Sankar Kumar Posted May 3, 2014 Share Posted May 3, 2014 Hi, If you are exporting millions of Flip or Particle simulations, instead of alembic use realflow connectivity plugins to export.... Its free plugin for all platforms... please check the attachment for Houdini Realflow plugin.. realflow2013_houdini_setup.zip Quote Link to comment Share on other sites More sharing options...
