Render View and AMD Graphics switching problem
houdini1987
I am using Houdini 13 build 260. My system has dual graphics card Intel HD and AMD Radeon 6700M Series. Problem is with my render view tab....When I try to render in render view to see some immediate change its all black unless i change my HOUDINI_OGL_SOFTWARE = 1. But on heavy render it crashes on software openGL mode.It works fine when I render normally using parameters. I read on different forums, its because my openGL render is still Intel HD. How to set my preferred openGl render to Radeon? My drivers are updated.  Below are houdini hardware data info. Please look into it and help me in resolving this issue.
Houdini FX Version 13.0.260
Platform:                 windows-x86_64-cl17
Operating System:         Windows 7 Service Pack 1 x64 (6.1.7601)
Number of Cores:          4
Physical Memory:          11.91 GB
OpenGL Vendor:            Intel
OpenGL Renderer:          Intel® HD Graphics 3000
OpenGL Version:           3.1.0 - Build 9.17.10.3347
OpenGL Shading Language:  1.40 - Intel Build 9.17.10.3347
Viewport Render Version:  GL 2.1
Detected:                 Intel HD Graphics Consumer
                          Unknown VRAM
                          9.17.10.3347
Supported OpenGL Extensions used by Houdini (Version):
    EXT_extensions_string
    GL_ARB_compatibility
    GL_ARB_depth_buffer_float               (3.0)
    GL_ARB_depth_clamp                      (3.2)
    GL_ARB_depth_texture                    (1.4)
    GL_ARB_draw_buffers                     (2.0)
    GL_ARB_draw_elements_base_vertex        (3.2)
    GL_ARB_draw_instanced                   (3.1)
    GL_ARB_explicit_attrib_location         (3.3)
    GL_ARB_fragment_shader                  (2.0)
    GL_ARB_framebuffer_object               (3.0)
    GL_ARB_half_float_pixel                 (3.0)
    GL_ARB_half_float_vertex                (3.0)
    GL_ARB_instanced_arrays                 (3.3)
    GL_ARB_map_buffer_range                 (3.0)
    GL_ARB_multisample                      (1.3)
    GL_ARB_multitexture                     (1.3)
    GL_ARB_occlusion_query                  (1.5)
    GL_ARB_occlusion_query2                 (3.3)
    GL_ARB_pixel_buffer_object              (2.1)
    GL_ARB_point_sprite                     (2.0)
    GL_ARB_seamless_cube_map                (3.2)
    GL_ARB_shader_bit_encoding              (3.3)
    GL_ARB_shader_objects                   (2.0)
    GL_ARB_shading_language_100             (2.0)
    GL_ARB_shadow                           (1.4)
    GL_ARB_sync                             (3.2)
    GL_ARB_texture_border_clamp             (1.3)
    GL_ARB_texture_buffer_object            (3.1)
    GL_ARB_texture_buffer_object_rgb32      (4.0)
    GL_ARB_texture_compression              (1.3)
    GL_ARB_texture_cube_map                 (1.3)
    GL_ARB_texture_float                    (3.0)
    GL_ARB_texture_non_power_of_two         (2.0)
    GL_ARB_texture_rectangle                (3.1)
    GL_ARB_texture_rg                       (3.0)
    GL_ARB_timer_query                      (3.3)
    GL_ARB_uniform_buffer_object            (3.1)
    GL_ARB_vertex_array_object              (3.0)
    GL_ARB_vertex_buffer_object             (1.5)
    GL_ARB_vertex_shader                    (2.0)
    GL_EXT_abgr
    GL_EXT_blend_color                      (1.4)
    GL_EXT_blend_func_separate              (1.4)
    GL_EXT_blend_logic_op                   (1.1)
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract                   (1.4)
    GL_EXT_fog_coord                        (1.4)
    GL_EXT_framebuffer_blit                 (3.0)
    GL_EXT_framebuffer_multisample          (3.0)
    GL_EXT_framebuffer_object               (3.0)
    GL_EXT_gpu_shader4                      (3.0)
    GL_EXT_packed_pixels                    (1.2)
    GL_EXT_polygon_offset                   (1.1)
    GL_EXT_texture                          (1.1)
    GL_EXT_texture3D                        (1.2)
    GL_EXT_texture_array                    (3.0)
    GL_EXT_texture_edge_clamp               (1.2)
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_integer                  (3.0)
    GL_EXT_transform_feedback               (3.0)
    GL_NV_conditional_render                (3.0)
    GL_NV_primitive_restart                 (3.1)
    GL_SGIS_texture_border_clamp            (1.3)
    GL_SGIS_texture_edge_clamp              (1.3)
Unsupported OpenGL Extensions used by Houdini:
    GL_ARB_base_instance                    (4.2)
    GL_ARB_debug_group                      (4.3)
    GL_ARB_debug_label                      (4.3)
    GL_ARB_debug_output
    GL_ARB_debug_output2                    (4.3)
    GL_ARB_geometry_shader4                 (3.2)
    GL_ARB_gpu_shader5                      (4.0)
    GL_ARB_gpu_shader_fp64                  (4.0)
    GL_ARB_robustness
    GL_ARB_sample_shading                   (4.0)
    GL_ARB_texture_multisample              (3.2)
    GL_ARB_texture_swizzle                  (3.3)
    GL_ARB_transform_feedback3              (4.0)
    GL_ARB_vertex_attrib_64bit              (4.1)
    GL_ATI_meminfo
    GL_EXT_direct_state_access
    GL_NVX_gpu_memory_info
    WGL_EXT_swap_control
Unused OpenGL Extensions:
    GL_3DFX_texture_compression_FXT1
    GL_ARB_color_buffer_float
    GL_ARB_copy_buffer
    GL_ARB_draw_buffers_blend
    GL_ARB_fragment_coord_conventions
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_framebuffer_sRGB
    GL_ARB_point_parameters
    GL_ARB_provoking_vertex
    GL_ARB_sampler_objects
    GL_ARB_texture_compression_rgtc
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_query_lod
    GL_ARB_texture_rgb10_a2ui
    GL_ARB_transpose_matrix
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_program
    GL_ARB_vertex_type_2_10_10_10_rev
    GL_ARB_window_pos
    GL_ATI_separate_stencil
    GL_EXT_bgra
    GL_EXT_blend_equation_separate
    GL_EXT_clip_volume_hint
    GL_EXT_compiled_vertex_array
    GL_EXT_draw_buffers2
    GL_EXT_draw_range_elements
    GL_EXT_gpu_program_parameters
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_float
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_specular_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_env_add
    GL_EXT_texture_env_combine
    GL_EXT_texture_lod_bias
    GL_EXT_texture_rectangle
    GL_EXT_texture_sRGB
    GL_EXT_texture_shared_exponent
    GL_EXT_texture_snorm
    GL_EXT_texture_swizzle
    GL_IBM_texture_mirrored_repeat
    GL_INTEL_map_texture
    GL_INTEL_performance_queries
    GL_NV_blend_square
    GL_NV_texgen_reflection
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_lod
    GL_WIN_swap_hint
OpenGL Limits:
   ELEMENTS_VERTICES                        1200
   ELEMENTS_INDICES                         1200
   FIXED_FUNCTION_TEXTURE_UNITS             8
   TEXTURE_COORDS                           8
   VERTEX_UNITS                             16
   FRAGMENT_IMAGE_UNITS                     16
   COMBINED_UNITS                           16
   TEXTURE_SIZE                             8192
   3D_TEXTURE_SIZE                          2048
   CUBE_MAP_TEXTURE_SIZE                    8192
   RECTANGLE_TEXTURE_SIZE                   8192
   TEXTURE_ARRAY_LAYERS                     256
   TEXTURE_STACK_DEPTH                      10
   FBO_ATTACHMENTS                          8
   DRAW_BUFFERS                             8
   VIEWPORT_DIMS                            8192x8192
   VERTEX_UNIFORMS                          512
   FRAGMENT_UNIFORMS                        1024
   VERTEX_ATTRIBS                           16
   VARYING_FLOATS                           41
   UNIFORM_BLOCKS                           24
   UNIFORM_BLOCK_SIZE                       16384
   UNIFORM_BUFFER_BINDINGS                  24
   COMBINED_VERT_UNIFORM_BLOCKS             12
   COMBINED_VERT_UNIFORM_COMPS              1
   COMBINED_FRAG_UNIFORM_BLOCKS             12
   COMBINED_FRAG_UNIFORM_COMPS              1
   TRANSFORM_FEEDBACK_INT_COMPS             64
   TRANSFORM_FEEDBACK_SEP_COMPS             4
   TRANSFORM_FEEDBACK_SEP_ATTRIBS           4
   LINE_WIDTH_RANGE                         0 - 6.99219
   LINE_WIDTH_GRANULARITY                   0.5
   POINT_SIZE_RANGE                         1 - 20
   POINT_SIZE_GRANULARITY                   0.125
OpenCL Platform           AMD Accelerated Parallel Processing
Platform Vendor           Advanced Micro Devices, Inc.
Platform Version          OpenCL 1.2 AMD-APP (1445.5)
OpenCL Device             Turks
OpenCL Type               GPU
Device Version            OpenCL 1.2 AMD-APP (1445.5)
Frequency                 485 MHz
Compute Units             6
Global Memory             1024 MB
Max Allocation            512 MB
Global Cache              0 KB
Max Constant Args         8
Max Constant Size         64 KB
Local Mem Size            32 KB
2D Image Support          16384x16384
3D Image Support          2048x2048x2048
OpenCL Platform Extensions:
   cl_khr_icd
   cl_khr_d3d10_sharing
   cl_khr_d3d11_sharing
   cl_khr_dx9_media_sharing
   cl_amd_event_callback
   cl_amd_offline_devices
   cl_amd_hsa
OpenCL Device Extensions:
   cl_khr_global_int32_base_atomics
   cl_khr_global_int32_extended_atomics
   cl_khr_local_int32_base_atomics
   cl_khr_local_int32_extended_atomics
   cl_khr_3d_image_writes
   cl_khr_byte_addressable_store
   cl_khr_gl_sharing
   cl_ext_atomic_counters_32
   cl_amd_device_attribute_query
   cl_amd_vec3
   cl_amd_printf
   cl_amd_media_ops
   cl_amd_media_ops2
   cl_amd_popcnt
   cl_amd_image2d_from_buffer_read_only
   cl_khr_spir
   cl_khr_gl_event
Environment:
    ALLUSERSPROFILE                        C:\ProgramData
    AMDAPPSDKROOT                          C:\Program Files (x86)\AMD APP\
    APPDATA                                C:\Users\ESH\AppData\Roaming
    CLASSPATH                              .;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/houdini/scripts/java/sesi.jar
    CommonProgramFiles                     C:\Program Files\Common Files
    CommonProgramFiles(x86)                C:\Program Files (x86)\Common Files
    CommonProgramW6432                     C:\Program Files\Common Files
    COMPUTERNAME                           ESH-VAIO
    ComSpec                                C:\Windows\system32\cmd.exe
    configsetroot                          C:\Windows\ConfigSetRoot
    FP_NO_HOST_CHECK                       NO
    HOMEDRIVE                              C:
    HOMEPATH                               \Users\ESH
    LOCALAPPDATA                           C:\Users\ESH\AppData\Local
    LOGONSERVER                            \\ESH-VAIO
    NUMBER_OF_PROCESSORS                   4
    OS                                     Windows_NT
    PATH                                   C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/python27;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/bin;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/toolkit/bin;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;c:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Sony\VAIO Startup Setting Tool;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64
    PATHEXT                                .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
    PROCESSOR_ARCHITECTURE                 AMD64
    PROCESSOR_IDENTIFIER                   Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
    PROCESSOR_LEVEL                        6
    PROCESSOR_REVISION                     2a07
    ProgramData                            C:\ProgramData
    PSModulePath                           C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
    PUBLIC                                 C:\Users\Public
    QTJAVA                                 C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
    RF_2013_PATH                           C:\Program Files\Next Limit\RealFlow 2013
    S6GA_HOME_DIR                          C:\ProgramData\GenArts\MonstersRaptors
    SESSIONNAME                            Console
    SystemDrive                            C:
    SystemRoot                             C:\Windows
    TEMP                                   C:/Users/~1/AppData/Local/Temp
    TMP                                    C:\Users\~1\AppData\Local\Temp
    USERDOMAIN                             ESH-VAIO
    USERNAME                               ESH
    USERPROFILE                            C:\Users\ESH
    windir                                 C:\Windows
    HFS                                    C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260
    HB                                     C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/bin
    HD                                     C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/demo
    HH                                     C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/houdini
    HHC                                    C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/houdini/config
    HT                                     C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/toolkit
    HTB                                    C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/toolkit/bin
    HSITE                                  C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/site
    JAVA_HOME                              C:/PROGRA~1/Java/jre6
    HOUDINI_OGL_SOFTWARE                   0
    USER                                   ESH
    HOME                                   C:/Users/ESH/Documents
    HOUDINI_TEMP_DIR                       C:/Users/~1/AppData/Local/Temp
    HOUDINI_DESKTOP_DIR                    C:/Users/ESH/Desktop
    JOB                                    C:/Users/ESH
    HIPNAME                                lamp.hip
    HIP                                    D:/skyDraft/workZ/Houdini
    PYTHONHOME                             C:/PROGRA~1/SIDEEF~1/HOUDIN~1.260/python27
    POSE                                   C:/Users/ESH/Documents/houdini13.0/poselib
    ACTIVETAKE                             Main
    DRIVER                                 mantra1
    DRIVERPATH                             /out/mantra1
    _HIP_SAVEPLATFORM                      windows-x86_64-cl17
    _HIP_SAVETIME                          Sun May  4 01:44:44 2014
    _HIP_SAVEVERSION                       13.0.260
    _HIP_SHELFTOOLCOUNT                    1
TEST FROM TOOL
Connected to ROOT\CIMV2 WMI namespace
 Name(__PATH) Value(\\ESH-VAIO\ROOT\CIMV2:Win32_VideoController.DeviceID="
VideoController1")
 Name(__NAMESPACE) Value(ROOT\CIMV2)
 Name(__SERVER) Value(ESH-VAIO)
 Name(__DERIVATION) Value(<unknown>) Type(8200) CIMType(8200)
 Name(__PROPERTY_COUNT) Value(59)
 Name(__RELPATH) Value(Win32_VideoController.DeviceID="VideoController1")
 Name(__DYNASTY) Value(CIM_ManagedSystemElement)
 Name(__SUPERCLASS) Value(CIM_PCVideoController)
 Name(__CLASS) Value(Win32_VideoController)
 Name(__GENUS) Value(2)
 Name(AcceleratorCapabilities) Value(2)
 Name(AdapterCompatibility) Value(Advanced Micro Devices, Inc.)
 Name(AdapterDACType) Value(Internal DAC(400MHz))
 Name(AdapterRAM) Value(1073741824)
 Name(Availability) Value(3)
 Name(CapabilityDescriptions) Value(3)
 Name(Caption) Value(AMD Radeon 6600M and 6700M Series)
 Name(ColorTableEntries) Value(-22964)
 Name(ConfigManagerErrorCode) Value(0)
 Name(ConfigManagerUserConfig) Value(<unknown>) Type(11) CIMType(11)
 Name(CreationClassName) Value(Win32_VideoController)
 Name(CurrentBitsPerPixel) Value(32)
 Name(CurrentHorizontalResolution) Value(1366)
 Name(CurrentNumberOfColors) Value(4294967296)
 Name(CurrentNumberOfColumns) Value(0)
 Name(CurrentNumberOfRows) Value(0)
 Name(CurrentRefreshRate) Value(59)
 Name(CurrentScanMode) Value(4)
 Name(CurrentVerticalResolution) Value(768)
 Name(Description) Value(AMD Radeon 6600M and 6700M Series)
 Name(DeviceID) Value(VideoController1)
 Name(DeviceSpecificPens) Value(23844)
 Name(DitherType) Value(0)
 Name(DriverDate) Value(20140417000000.000000-000)
 Name(DriverVersion) Value(14.100.0.0)
 Name(ErrorCleared) Value(-7868)
 Name(ErrorDescription) Value(-7868)
 Name(ICMIntent) Value(-7868)
 Name(ICMMethod) Value(-7868)
 Name(InfFilename) Value(oem130.inf)
 Name(InfSection) Value(ati2mtag_VancouverA)
 Name(InstallDate) Value(23844)
 Name(InstalledDisplayDrivers) Value(aticfx64.dll,aticfx64.dll,aticfx64.dll,atic
fx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,
atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll)
 Name(LastErrorCode) Value(516)
 Name(MaxMemorySupported) Value(516)
 Name(MaxNumberControlled) Value(516)
 Name(MaxRefreshRate) Value(59)
 Name(MinRefreshRate) Value(59)
 Name(Monochrome) Value(<unknown>) Type(11) CIMType(11)
 Name(Name) Value(AMD Radeon 6600M and 6700M Series)
 Name(NumberOfColorPlanes) Value(-22964)
 Name(NumberOfVideoPages) Value(-22964)
 Name(PNPDeviceID) Value(PCI\VEN_1002&DEV_6741&SUBSYS_9080104D&REV_00\4&274E30E8
&0&0008)
 Name(PowerManagementCapabilities) Value(-12)
 Name(PowerManagementSupported) Value(-12)
 Name(ProtocolSupported) Value(-12)
 Name(ReservedSystemPaletteEntries) Value(-12)
 Name(SpecificationVersion) Value(-12)
 Name(Status) Value(OK)
 Name(StatusInfo) Value(-31692)
 Name(SystemCreationClassName) Value(Win32_ComputerSystem)
 Name(SystemName) Value(ESH-VAIO)
 Name(SystemPaletteEntries) Value(24636)
 Name(TimeOfLastReset) Value(24636)
 Name(VideoArchitecture) Value(5)
 Name(VideoMemoryType) Value(2)
 Name(VideoMode) Value(2)
 Name(VideoModeDescription) Value(1366 x 768 x 4294967296 colors)
 Name(VideoProcessor) Value(AMD Radeon Graphics Processor (0x6741))
VideoController2")
 Name(__RELPATH) Value(Win32_VideoController.DeviceID="VideoController2")
 Name(AdapterCompatibility) Value(Intel Corporation)
 Name(AdapterDACType) Value(Internal)
 Name(AdapterRAM) Value(-2084569088)
 Name(Availability) Value(8)
 Name(CapabilityDescriptions) Value(8)
 Name(Caption) Value(Intel® HD Graphics 3000)
 Name(ColorTableEntries) Value(23772)
 Name(CurrentBitsPerPixel) Value(23844)
 Name(CurrentHorizontalResolution) Value(23844)
 Name(CurrentNumberOfColors) Value(23844)
 Name(CurrentNumberOfColumns) Value(23844)
 Name(CurrentNumberOfRows) Value(23844)
 Name(CurrentRefreshRate) Value(23844)
 Name(CurrentScanMode) Value(23844)
 Name(CurrentVerticalResolution) Value(23844)
 Name(Description) Value(Intel® HD Graphics 3000)
 Name(DeviceID) Value(VideoController2)
 Name(DitherType) Value(23844)
 Name(DriverDate) Value(20131031000000.000000-000)
 Name(DriverVersion) Value(9.17.10.3347)
 Name(InfFilename) Value(oem104.inf)
 Name(InfSection) Value(iSNBM0)
 Name(InstallDate) Value(-7828)
 Name(InstalledDisplayDrivers) Value(igdumd64.dll,igd10umd64.dll,igd10umd64.dll,
igdumd32,igd10umd32,igd10umd32)
 Name(LastErrorCode) Value(-12)
 Name(MaxMemorySupported) Value(-12)
 Name(MaxNumberControlled) Value(-12)
 Name(MaxRefreshRate) Value(-12)
 Name(MinRefreshRate) Value(-12)
 Name(Name) Value(Intel® HD Graphics 3000)
 Name(NumberOfColorPlanes) Value(23844)
 Name(NumberOfVideoPages) Value(23844)
 Name(PNPDeviceID) Value(PCI\VEN_8086&DEV_0116&SUBSYS_9080104D&REV_09\3&11583659
&0&10)
 Name(StatusInfo) Value(-7828)
 Name(VideoModeDescription) Value(2)
 Name(VideoProcessor) Value(Intel® HD Graphics Family)
Done enumerating display drivers!
Enumerating display devices...
  DeviceName(\\.\DISPLAY4)
  DeviceString(Intel® HD Graphics 3000)
  StateFlags(5)
  -> DISPLAY_DEVICE_ACTIVE
  -> DISPLAY_DEVICE_PRIMARY_DEVICE
  DeviceID()
  DeviceKey(\Registry\Machine\System\CurrentControlSet\Control\Video\{7B1480BF-4
D5E-4313-994C-793BC53D12AB}\0000)
  DeviceName(\\.\DISPLAY5)
  StateFlags(134217728)
  -> DISPLAY_DEVICE_MODESPRUNED
  DeviceID()
D5E-4313-994C-793BC53D12AB}\0001)
  DeviceName(\\.\DISPLAYV1)
  DeviceString(RDPDD Chained DD)
  StateFlags(8)
  -> DISPLAY_DEVICE_MIRRORING_DRIVER
  DeviceID()
  DeviceKey(\Registry\Machine\System\CurrentControlSet\Control\Video\{DEB039CC-B
704-4F53-B43E-9DD4432FA2E9}\0000)
  DeviceName(\\.\DISPLAYV2)
  DeviceString(RDP Encoder Mirror Driver)
  StateFlags(2097160)
  DeviceID()
  DeviceKey(\Registry\Machine\System\CurrentControlSet\Control\Video\{42cf9257-1
d96-4c9d-87f3-0d8e74595f78}\0000)
  DeviceName(\\.\DISPLAYV3)
  DeviceString(RDP Reflector Display Driver)
  StateFlags(2097160)
  DeviceID()
  DeviceKey(\Registry\Machine\System\CurrentControlSet\Control\Video\{b043b95c-5
670-4f10-b934-8ed0c8eb59a8}\0000)
Done enumerating display devices!
NVIDIA Optimus Detected: NO
