How to make a velocity layer in hou13
I was having the same question right now :))
at the moment, I am rendering my usual passes in Houdini, then cache out and render the velocity in 3dsmax, MR, as I know the output there and how to use it...
it would be nice to do it in Houdini though :)
  • 3 weeks later...
hi Marty,
but that´s a velocity pass, not a motion vector pass, is it?
I mean, I´m still using the method of subtracting the GetBlurP from one frame of the previous one...I understand that´s still the current method?
Then again, it´s not clear what people wants. Some of them ask for velocity and others for a motion vector...
Edited by Netvudu
marty, Netvudu, could you possibly enlighten us on the motion vector pass as well ?
GetBlurP ?..
  • 2 months later...
Hi !
I hope this post is still alive :)
Given that the point velocity attribute is already on the geometry I am rendering,
the way I've always exported my velocity pass is simply binding "v" into a mantra material builder, transforming from "world" to "camera" ("direction" mode) , sometimes multiplying by 1/24 and exporting.
In general I use this pass to add motion blur in comp via Nuke, and it seems to work quite well.
I 've seen several threads about exporting velocity and I am pretty sure I am missing something, cause in general people use more elaborated ways to do that.
There is an issue with this, in that the camera velocity is not taken into account... This a problem if the camera is moving with the object, and numerous other situations :( ... on my list of things to look at properly, but I think it will probably involve sidefx support/fix. Its a problem whether you are exporting vectors or even rendering 3d blur.
