No options under mantra node Properties > PBR
DocWhite
Hello guys. I am having some problems with the options under the PBR tab inside Properties of my Mantra node. I generated a photons map and I need to interpret it with a PBR render node. I cannot select the maps because I don't have the options.
Any ideas why could this be happening?
Thank you very much guys!
post-10566-0-31245200-1399671112_thumb.p
  • 2 weeks later...
What are you trying to do?
Photon maps are used by lights i.e. Caustics etc.
Yeah I want to do caustics. I found a solution to the problem, by editing the Parameter Interface I can bring some parameters into a tab called "Photon" under the render node. But then I realized there is an environment caustic light that does the job automatically, this is great.
