Guest mantragora Posted May 10, 2014 Share Posted May 10, 2014 (edited) Or maybe I'm missing something? Can I extract "identyficator" or "type" somehow from this code? <?xml version="1.0" encoding="utf-8" ?> <Nodes> <SOP> <Node identyficator="0"> <Defaults> <Name type="internal">hdk_sop_foo</Name> <Name type ="external">SOP Foo</Name> <Name type="iconname">SOP_Foo</Name> <Name type="iconextension">svg</Name> <Name type="version">1.0</Name> </Defaults> <Parameters> <Parm identyficator="0"> <Name type="internal"></Name> <Name type="external"></Name> </Parm> <Parm identyficator="1"> <Name type="internal"></Name> <Name type="external"></Name> </Parm> </Parameters> </Node> </SOP> <DOP> </DOP> </Nodes>There are only four methods available in UT_XMLNode, and it doesn't look that any of it gives access to attributes.And what is getContents() method returning? Quote /// Return the contents of the node. /// Return an empty string if this is not a contents node. WTF is this? I always get blank string with it, so what should be specified in the node to get some data with it?Thanks! Edited May 10, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted May 11, 2014 Share Posted May 11, 2014 (edited) I moved my project to PUGIXML, which works more like .NET XML implementation. But still I would like to see some examples, if there is attribute support in UT_XML* classes. Edited May 11, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted May 13, 2014 Share Posted May 13, 2014 It looks that there is more than one XML parser in HDK. One is UT_XMLDomParser and the second is UT_XMLSaxParser. The second one does have attribute support, but all the methods that touches attruibutes are protected, so I can't access them. Any tips? Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted May 13, 2014 Share Posted May 13, 2014 Hmm..., maybe I should just use UT_XMLReader class instead of those two Parser classes? What's the difference between those classes? Why do we have 3 possibilities on how to parse the file? Quote Link to comment Share on other sites More sharing options...
