Creating Camera HDA
I wanted to build a custom camera node, but I didn't want to have the camera inside a subnet and create the otl, so I selected the default camera and created Digital Asset. I got some error about parameter layout modified but everything seems to work fine.
The only problem is that Background Image will not be visible in the viewport. Its there for sure, visible on rendering, the path is also visible on Display Options/Background/Camera but not on viewport.
What can cause this? How can I fix it or how can I build a custom camera node?
Cheers
