reference a geometries vector in a vop sop
I am following a tutorial that built a flocking system with VEX and I am building something similar in a VOPSOP but cant figure out the nodes to use for the vex  optransform(opPath).
I basically want to bring in an objects position to use as a goal in VOPS and am struggling to find a way of referencing the object VOPS.
Any help would be greatly appreciated.
Thanks
I would probably create a parameter node and set the variable type to three floats. Then at the VOPSOP node level use an expression to point to the object position with something like centroid or a specific point location. There's also this, but it might not be as flexible as a parameter expression.
http://www.sidefx.com/docs/houdini13.0/nodes/vop/getobjxform
Edited by lukeiamyourfather
