VEX volume procedural shader: World space in CVEX shader?
Probably an obscure question...
I am using the VEX Volume Procedural. It is working nicely but in the docs it states:
The following inputs parameters are available in the CVEX context used by the VEX Volume Procedural:
- P Position to evaluate, in object space.
Now I would actually like to get the world space position. It seems not that important but in my case I would to instance several (procedural holders) pointing to the same geometry shader and cvex shader.
Like I said, obscure question but it doesn't hurt to ask right?
Cheers,
Rog.
As usual, posting a question in a forum leads to me finding the answer myself shortly after  :)
It turns out I can use the instancepoint() expression in a parameter on the cvex shader. That allows me query the world space transform of the instance currently being rendered and feed that into the cvex shader.
Rog.
