delete fluid particles
muzaffer
Hi People,
My question might be answered before but could not find suitable answer.
I am suffering to delete some unwanted polygon used particle fluid surface node.
basically I am running particle fluid than meshing with particle fluid surface node. but some tiny polygon flying around.
how to use measure sop find them and delete.
Thank you for helping
You can:
-measure the area of each poligon
-use connectivity sop to separate conneced surfaces
-use foreach sop to iterate thorugh each conneced piece
inside foreach:
-add attributepromote to promote area attribute from prim to detail and set promotion method to Sum
-then use delete sop, based on detail area value and delete piece if area is too small
