gpapaioa Posted July 24, 2014 Share Posted July 24, 2014 Hello ppl My case is the following: i am matching a real mirror like surface with a CG one. In my scene, other CG geometry is reflected and I want to comp this reflection pass to the real plate. But because of the alpha I get black wherever there is nothing reflected (as expected). I tried to do a luma key in Nuke but doesn't work very good with the edges, due to the fact there are volumes involved. Does anyone know if its possible to make the reflection drive the opacity so whenever there is nothing reflected, alpha will turn to black? Thank you. Quote Link to comment Share on other sites More sharing options...
xray Posted August 11, 2014 Share Posted August 11, 2014 This is a bit of a hack I think... Check to see if the length of the color of the reflection is greater than zero and send the result to the Alpha in the shader. Here's an example. alphaRefl.hip Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted August 18, 2014 Author Share Posted August 18, 2014 Thank you very much this is exactly what I was looking for. I must study about CVEX and custom shaders. Quote Link to comment Share on other sites More sharing options...
fathom Posted August 18, 2014 Share Posted August 18, 2014 the "trace" vex operation will return color and opacity (and alpha) from the traced vector. Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted August 19, 2014 Author Share Posted August 19, 2014 I am now experiencing another problem. Since I want only object reflection and not light reflection, it seems that i get reflection only from smoke and not from fire. Is there a solution for this? I assume it happens because the Pyro Shader treats fire like emission. Here's a still, the explosion is reflected on the glass building Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted September 7, 2014 Author Share Posted September 7, 2014 (edited) [sOLVED] the Emission Illuminates Object on the Pyro Geometry node was uncheck by default . So Emission wasnt calculated on the secondary rays. Edited September 7, 2014 by gpapaioa Quote Link to comment Share on other sites More sharing options...
