mcbiovision
jms
Hello to  everyone
I want to transfer .bvh to .cmd file with mcbiovision command line tool but I don´t understand very well the syntax
mac-pro-de-jms:~ JMS$ mcbiovision -e -c -o -j /walking_2.bvh /walking_2.cmd
Unable to open /walking_2.cmd for reading
mac-pro-de-jms:~ JMS$ mcbiovision -e -c -o -j ./walking_2.cmd
Usage:
  mcbiovision [-e -b -d] [-c] [-v] [-j object_script]
 [-o -w -f -s -i [-n -t -l chainfile]]
   infile [outfile]
This program converts a BioVision motion file to
a Houdini script & channel file(s).  Run the script
to create the geometry and channels.
 -e Parms are stuffed with expressions (chop, default).
 -b Parms are left blank.
 -d Parms are left blank and override channels created.
 -c Only create the channel file(s).
 -v Reverse joint rotation order.
 -o Create character using object joints.
 -s Name bones using only the end joint name, instead
of combining start and end names.
 -w Create character using object joints + wire polys.
 -j Set the object creation script (eg "opadd geo %s").
 -f Create character using Forward Kinematics (default).
 -i Create character using Inverse Kinematics:
 -n Specifies bone length channel type (FK,IK only).
   0 = none, 1 = always, 2 = auto).
 -t Dual bone chains with twist affectors (IK only).
 -l Specifies a file containing a list of bone chains (IK only).
Each line of the file must be of the form:
<IK Chain Root Joint> <IK Chain End Affector>
mac-pro-de-jms:~ JMS$ mcbiovision -e -c -o -j /walking_2.bvh -o walking_2.cmd
Unable to open walking_2.cmd for reading
mac-pro-de-jms:~ JMS$ mcbiovision -e -c -o -j /walking_2.bvh /walking2_
Any one knows how to do it, I´m pretty sure that it´s really easy and iI'm sure it's my fault.
greatly appreciate it
Thank you all in advance
Remove the slashes in front of your paths because with it, it means that you're trying to write to the root directory, which you probably don't have write permission for.
mcbiovision -e -c -o -j walking_2.bvh -o walking_2.cmd
