whodini Posted August 25, 2014 Share Posted August 25, 2014 Anyone ever get an error "Error: Tried to load an invalid simulation state file" when assigning an initial state file to a dopnetwork node? My initial state file is about 14GB in file size, and I'm getting this error with smaller files too. I used the initial state for a duplicate version of my dopnet (I have the initial state simulation, and another dopnet that I apply the init state to) Quote Link to comment Share on other sites More sharing options...
ryew Posted August 25, 2014 Share Posted August 25, 2014 How small is the smaller file you are still getting the error with? Have you successfully been able to use initial state files 1 GB or greater in the recent past? In H12 had a problem with pyro sims where the largest initial state file I could get to work was under 500MB, while any files of a more typical size (1 GB or greater) would never work. Other artists had the same issue, so the general consensus was that it was broken or had limitations that were not explicitly stated. I gave up on the initial state functionality after wasting a considerable amount of shot time trying to debug it. If any of the SESI folks that peruse these forums could clarify the limitations of the initial state files, that would be very helpful Quote Link to comment Share on other sites More sharing options...
whodini Posted August 25, 2014 Author Share Posted August 25, 2014 Wow, yea your right there seems to be some sort of limitation for the init state files. It appears the smaller files are working but not the larger ones over 500mb. Kind of disappointing. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 25, 2014 Share Posted August 25, 2014 send the bug report in! Don't settle for disappointment Quote Link to comment Share on other sites More sharing options...
whodini Posted August 26, 2014 Author Share Posted August 26, 2014 filed bug report with sesi and confirmed the issue exists on another build 13.0.376 as well Quote Link to comment Share on other sites More sharing options...
