Copying Debris Pieces
henrik.g
Hey everyone!
I am trying to create a system with which I can copy debris pieces onto a surface.
Should be super simple I thought, yet I already seem to fail at the Copy SOP.
I have written out some *.bgeo pieces.
I load them back via file SOP and then have a stamping expression in the file path, which looks like this:
$HIP/Pieces/Debris.`int(fit01(rand(stamp("../copy_pieces", "p", 100)), 1, 470))`.bgeo
The file SOP doesn't complain.
The Copy does:
 Invalid Source box:
What am I missing?
File attached!
And thanks so much in advance!
DebrisPieces1.hipncFetching info...
You are writing the debris pieces starting from 101, but you are trying to read pieces with numbers 1-100 as well.
Change your expression to $HIP/Pieces/Debris.`int(fit01(rand(stamp("../copy_pieces", "p", 100)), 101, 470))`.bgeo
