Transformers Cubes
khalid
Hi MightCouldb1
thanks for the .hip , its a nice try :), but in your setup its all about  Random events, not really like the reference. i thought it was not very hard to do but still can't and people here too.maybee finally its a hard thing to do with houdini.good challenge
Here's my attempt:
transformer_cube.hipnc
Things that need some love:
  • When the number of points gets low, the cubes start to move on angles; their movement should always be restricted to straight lines
  • I can't make the first frame be a clean rest state, it always has a few cubes shifted by a small amount. I'm sure its an easy fix, but I couldn't see it
  • Can you pass parameters to instance objects to be read by a material? I can colour the moving cubes if I use a copy, but couldn't work out a way with fast point instancing
  • Maybe tag a 'target' cube, so that all the cubes try and march themselves to a common goal
Anyway, hope it helps. :)
Edited by mestela
  • Like 6
  • Thanks 1
  • 1 year later...
