Whatsinaname Posted September 5, 2014 Share Posted September 5, 2014 For something like a wetmap effect I need to write an object's color information to a texture map, based on the object's UVs. Unfortunately, I have no clue how that works, so any suggestions are more than welcome. In order to illustrate the problem a bit, I attached my file so you can probably see what I am about to. ...the reason for doing so is the texture will be used in a different 3d application. colTex_test.hipnc Quote Link to comment Share on other sites More sharing options...
kleer001 Posted September 5, 2014 Share Posted September 5, 2014 I too am interested in this. I tried a few futile ways, but ended up with a mess. I think you'd be writing out an image in COPS, but beyond that I'm lost. Quote Link to comment Share on other sites More sharing options...
SaleVonGeist Posted September 5, 2014 Share Posted September 5, 2014 +1 for any info about this. Quote Link to comment Share on other sites More sharing options...
Shinjipierre Posted September 6, 2014 Share Posted September 6, 2014 You can render that using UV render object in mantra ROP (properties/render), it'll render a UV based texture Quote Link to comment Share on other sites More sharing options...
SaleVonGeist Posted September 6, 2014 Share Posted September 6, 2014 Thanks for the tip Remi, it works nicely. Found few other threads on this topic, and one important thing is to make sure that UVs are applied as vertex attributes. Quote Link to comment Share on other sites More sharing options...
