for each attribute value vex equivalent
sekow
I am having this problem at hand where I need to loop thru clusters of points and calculate the average position. These points are organized with a cluster id attibute (clsID). Can't really figure out how to do this in VEX.
So far I have a For Each Sop (looping thru each attribute value) with two attrbPromote Sops attached in line. First is promoting @P to detail attribute ('center') via average, second is reapplying @center to points again.
Help is much appreciated
-sebastian
in vex you could use nuniqueval() and uniqueval() to iterate over attributes. the following link might put you on the right track: http://forums.odforce.net/topic/20814-need-help-with-python-vex/?p=124375
if it doesn´t has to be vex, the attached example is probably the easiest way to do it...
hth.
petz
centroid.hipnc
Edited by petz
