soot creatures with attribvop
mestela
Was messing around with attribvops and creating edges, this stumbled out by accident, thought others might find it interesting. Wanted to post it in the 'learning vopsop' thread, but its not a vopsop, and it might go through a few fiddly things that'd confuse the learning process, so I'll post it here instead:
soot.hipncFetching info...
2 scatters, one for ground points, one for the soot creatures. wobble the soot points with a vopsop, group, merge with the ground points, then grow some legs in an attribvop.
the attribvop first isolates the soot points, does a point cloud lookup for the nearest 8 points, and on each it creates a primitive and uses addvertex to connect the soot point to that ground point. simple!
i was originally going to try a plexus style thing, but found this more entertaining. :)
