-HEAVY- Posted October 1, 2014 Share Posted October 1, 2014 (edited) Hey =] i have a complex wooden Fence here i am actually destroying and get stuck at keeping it all procedurally. the main problem is that the fence is based on a curve that is sometimes going in z and sometimes in x direction and shurely sometimes transverse but the good thing is, the fence has poles planks and supports - Wood-shattering the planks and poles is good. cause everything is vertical. when it comes to the supports I thought I foreach through the parts and do the same as non procedurally -> Cookie -> transform -> shatter -> transform back -> merge - but i dont know how to cookie and seperate based on direction. so if somebody has time to dig in my complex file it would be a great help. Play around, examine, and if you fix something please provide me with some info to the fix. and if there are questions i am here. thx de Heavy FenceBaseSetup.crash.hipnc Edited October 1, 2014 by -HEAVY- Quote Link to comment Share on other sites More sharing options...
-HEAVY- Posted October 6, 2014 Author Share Posted October 6, 2014 Hmmm..9downloads of the file, but no answer, seems i have to specify a bit. Ok. What about getting the center between two poles? I think when i have the center position between the poles i can attach a box and cookie out the parts. So how do i get these center position? Quote Link to comment Share on other sites More sharing options...
Joshi Posted October 9, 2014 Share Posted October 9, 2014 Something like this will work for adding center point between two poles.CheersHimanshu Fence_add_center_point.hipnc Quote Link to comment Share on other sites More sharing options...
-HEAVY- Posted October 10, 2014 Author Share Posted October 10, 2014 Haha.. so simple i never thought about shifting the points. But if i use a box- which i need for the cookie operation - it gives unwanted results on the points of the box. And when i use a delete to remove the shiftet spheres with keep points on, so that i can copy a box to that points, i am not able to align the cubes to the normal so they are correctly in flow with the curve... Quote Link to comment Share on other sites More sharing options...
Joshi Posted October 10, 2014 Share Posted October 10, 2014 Can you post a .hip file? Quote Link to comment Share on other sites More sharing options...
