RAT vs EXR Mipmaps
Hi all,
So, to futureproof digital assets (say to support both Mantra and Arnold) and also to get the best downscaling filter possible (say Lanczos6, if that is not already what iconvert uses) should I (is it even possible with Mantra?) use EXR mipmaps (generated with maketx)?
If I cannot use EXR mipmaps with Mantra, can Cortex' RATWriter be used to write a batch-converter or a Nuke plugin to write Lanczos6-filtered RAT mipmaps?
Thanks!
Vincent
  • 5 months later...
  • 1 year later...
The SESI post is a bit old I think. I have tiled and mipmaped exrs (a lot) 7 textures with UDIMs(160 tiles each one of them) . The setup is for htoa and i want to port it to mantra. Anyone knows why is not possible for mantra to use the exr versions? If thats the case, do I need to write a python to convert all of them ?
