Problems with Camera from Alembic Scene
Hi ,
I have a problem with an Alembic scene.
I have received an Alembic scene with camera in order to make a lighting and shading process .
I used the camera from Alembic to make the test render, and once completed and I wanted to send the scene back, but I can not export Alembic again because I have Aprentice HD licence.
So, when I change the path of the camera from Alembic to $HIP, as if I create a new camera with the same position of the original, it change the shading , lighting, and even I can see errors in the geometry.
What could be the problem?
Alembic Camera will only work on the top "/obj" Context. Drop an alembic node under OBJ, point to the alembic scene with camera, and do selection picker to isolate just the camera.
For everything else, load the same alembic path under a GEO node.
