pintoanimation cloth not working in H13?
danieljhourigan
Does the pintoanimation attribute work with cloth in H13?
Simple .hip file attached, what am I doing wrong?
I am pulling my hair out trying to figure out cloth in H13. trying to learn from the crumpling masterclass but I cant get any of the files to work in H13!!!  :(
Hope somebody can shed some light on this.
Thanks
pintoanimation_test.hipnc
yeah... I'm not sure that masterclass relates too much to Houdini's current cloth workflow. You might want to take a look at the help card for the cloth object or at least the FEM masterclass.
From help card:
pintoanimation, Point, Float, Enable hard constraint to targetP and targetv.
Basically means that without targeP and targetV attributes, pintoanimation is worthless. Enable target options on cloth object and then create a velocity attribute in SOP level so that your pintoanimation can have effect.
Cheers
pintoanimation_test_fixed.hipnc
