idini Posted August 26, 2002 Share Posted August 26, 2002 Hi, I am trying to use the data in a midifile (channel 6) to drive the scale parameter of a fractal SOP. I know Houdini can make light work of such stuff but I just need some pointers. Any and all help is appreciated! Cheers, Dave Quote Link to comment Share on other sites More sharing options...
danteA Posted August 26, 2002 Share Posted August 26, 2002 Add a Midi In CHOP, specify your MIDI Source, specify 6 in the "MIDI Channels", drag and drop the name of the track in the chop viewer onto the scale parameter of your fractal sop. Quote Link to comment Share on other sites More sharing options...
idini Posted August 26, 2002 Author Share Posted August 26, 2002 Thanks for the reply. When I try this I get the red 'error' flag on the fractal SOP though. Probably something I'm doing. I'll tinker with it some more. Thanks again, Dave Quote Link to comment Share on other sites More sharing options...
danteA Posted August 26, 2002 Share Posted August 26, 2002 if you middle-click on the tile, what does the error say? Quote Link to comment Share on other sites More sharing options...
idini Posted August 26, 2002 Author Share Posted August 26, 2002 As follows: 'Error: Unable to evaluate expression (Expression stack error (/obj/model/fractal1/scale))" ? Quote Link to comment Share on other sites More sharing options...
danteA Posted August 26, 2002 Share Posted August 26, 2002 Uh, did you choose "Export CHOP" when you dragged the chop name onto the parameter? Quote Link to comment Share on other sites More sharing options...
idini Posted August 26, 2002 Author Share Posted August 26, 2002 No, I didn't see any options when dragging the CHOP name. I'll try again. Thanks, Dave Quote Link to comment Share on other sites More sharing options...
idini Posted August 26, 2002 Author Share Posted August 26, 2002 Ok, I've got it now. Apologies, I mis-read your initial instructions. Cheers, Dave Quote Link to comment Share on other sites More sharing options...
