image sequence as texture but then some
<_< One shader, one hundred squares, one image seguence, sounds easy so far accept that I'd like each square to be showing a different image out of the sequence. Can it be done? I've tried a VEX_SuperShader with an expression in diff that reads a prim attribute I created for each square, like
testA.`prim("obj/model/attribcreate1/",$PR,"test",0)+$F`.jpg
the shader just turns red...
I'd love any suggestions
austin
  • 13 years later...
