moam1986 Posted November 21, 2014 Share Posted November 21, 2014 guys help please i can't break cloth to cloth "hard constrain" with "two state constraint relationship" because it don't returning a force value unlike the rbd and wires!! i had attached simple file show you the issue.. hope you guys have solution for this issue! test_contraint_H13.hip Quote Link to comment Share on other sites More sharing options...
moam1986 Posted November 22, 2014 Author Share Posted November 22, 2014 guys i wanna any breakable constraint work with clothes.. any ideas?!! Quote Link to comment Share on other sites More sharing options...
shaan Posted August 14, 2015 Share Posted August 14, 2015 Hey man, probably you must have figured this out but just in case if you havent, the way i did it was made a group of points inside a sopsolver and then i had used a sbdpinconstraint node and on the constrained object just point it to your sopsolver group.also inside the sbdpinconstraint, on anchorobjpointgroup pos set the default operation to set always and that will help in updating the constraints from sops. Hope this helps Quote Link to comment Share on other sites More sharing options...
Sankar Kumar Posted May 23, 2016 Share Posted May 23, 2016 On 14/08/2015 at 11:29 PM, shaan said: Hey man, probably you must have figured this out but just in case if you havent, the way i did it was made a group of points inside a sopsolver and then i had used a sbdpinconstraint node and on the constrained object just point it to your sopsolver group.also inside the sbdpinconstraint, on anchorobjpointgroup pos set the default operation to set always and that will help in updating the constraints from sops. Hope this helps An example please... Quote Link to comment Share on other sites More sharing options...
