Sierra62 Posted November 28, 2014 Share Posted November 28, 2014 I am trying to add Displacement Bound to a mantra surface shader. I have tried adding it through the parameters interface but it's greyed out and won't let me add it. Is there another way to add it? or is it already in the shader? Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 28, 2014 Share Posted November 28, 2014 Try adding the parameter to the objects that will use that material. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 28, 2014 Author Share Posted November 28, 2014 I can do that, but I am trying to build a digital asset out of the shader and I would prefer to not have to always add it to the geometry when I use the asset. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 28, 2014 Share Posted November 28, 2014 (edited) That's usually not how it's done but it should still work. See the attached scene. EDIT: Upload didn't work for some reason, trying again... Edited November 28, 2014 by lukeiamyourfather Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 28, 2014 Author Share Posted November 28, 2014 I think you may have forgotten to attach it. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 28, 2014 Share Posted November 28, 2014 Attachment should work this time. displacementBoundTest.hip Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 28, 2014 Author Share Posted November 28, 2014 Thanks Luke, I have been able to get the displacement bounds on a new custom material like the one you've done. But I have been trying to get it onto one of the default mantra surface materials and it won't let me. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 28, 2014 Share Posted November 28, 2014 Which one of the default materials are you trying to use? Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 28, 2014 Author Share Posted November 28, 2014 The material I am trying is the mantra surface. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 28, 2014 Author Share Posted November 28, 2014 I also just failed to attach a file displacementBoundTest.hip Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 28, 2014 Share Posted November 28, 2014 The Mantra Surface shader that comes with Houdini already has the parameter added which is probably why it shows as grayed out when trying to add it again. On the shader parameters look under the Displacement tab, then Displacement Map tab, it's the third parameter down. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 28, 2014 Author Share Posted November 28, 2014 Thanks Luke, I feel like an idiot for missing it. I think I have spent almost a day trying to find it. Quote Link to comment Share on other sites More sharing options...
