Fracture OBJ Problem
johnsonmax
I'm new to Houdini so this might be a very silly question.
I'm playing with Voronoi Fracturing.
I got it simulating with a small cube but when I replace that cube with a simple stair.obj model, it seems there is some gaps. It still has a different simulation/effect.
post-12532-0-74888600-1417296990_thumb.j
First you can turn on "check box"
Show Collision Guide Geometry
are you using Bullet Data
try switching to RBD solver for the Collision ,
this way the Collision geometry will match the shape of the Object
Here In the Snaps.
Put up the scene to help you fix it
cheers
Mangi
post-2848-0-18684700-1417301978_thumb.jp
post-2848-0-68066200-1417301996_thumb.jp
Max, well I was waiting for your upload of the stair model.
I made one myself just for the  test.
I guess with some tweaks you can get a collision working okay in your example
& the bulletrbdsolver
This would be the result:
cheers
and good luck with your training with Houdini
mangi
post-2848-0-61178500-1417362238_thumb.jp
post-2848-0-82290200-1417362256_thumb.jp
post-2848-0-46136400-1417362271_thumb.jp
post-2848-0-80860400-1417362287_thumb.jp
post-2848-0-55360200-1417362315_thumb.jp
post-2848-0-54703300-1417362332_thumb.jp
